10 to the power of .......
Jay 1987
Trainee
starting to get my head around the maths, but I have a question in the example equation 10 to the power of 6 has turned to 10 to the negative 6 why is this the case ?
Because the 10 ^ 6 is on the bottom.
400
2 x 10^6
Is the same as
400 x 10^-6
Just in case you're not familiar with the notation.... x ^ y is x to the power y.
I should add, basically when you flip a number to a power like that between the top and bottom of a division, you negate it's power.
So... 1 / 2^2 = 1 x 2^-2.
So 10 ^6 when on the bottom is positive
And when on the top is negative ?
Is this the correct principle in all situations?
Or does it vary ?
10^6 = 1 million.
So, if you divide 1 by 1000000 you'll get 0.000001, which is 10^-6.
1/10^6 = 10^-6
1/10^-6 = 10^6
You change the sign when you move the number from the numerator (top of the fraction/division) to the denominator (bottom of the fraction/division) or vice versa.
This one you used the example of division turning into multiplication with the positive turning to minus. I get this one
10^6 = 1 million.
1/10^6 = 10^-6
1/10^-6 = 10^6
This one there both fractions. I don’t get this one ?
So let's take the first one...
10^6
This is the same as writing
1 x 10^6
Which is the same as writing
Which equals 0.0000001 or 1 x 10^-6.
1 x 10^-6
As @westward10 says, the mathematical terminology is transposition.
Ok so I’m back!
I = V
————. Work out I = current
R
400 v
2 x 10 ^6 ohms Is the same as
400
2,000,000.
As 2 mega ohms is 2,000,000 ohms
Is this part correct, I need to do it in stages
If I divide. 400. I get
————. = 0.002
2,000,000
What am I doing wrong ?
It is slightly wrong, but I suspect it's a typo... the correct answer is 0.0002 Amps, 0.2mA (milli-amps) or 200uA (micro-amps).
Why do you think you're doing it wrong?
1v across a resistance of 1 ohm is 1 amp. 100v across 1 ohm is 100 amps. 1v across 100 ohm is 0.01 amp.
So as voltage increases, current increases, as resistance increases, current decreases.
