Hi there.
I've been looking for a while for a power solution to run 128 x 6w (Initial load) mini board computers.
I've looked at USB charging blocks that can provide 100w over 8 ports, that means I need 8 of them and splitting each port is a bugger for cabling.
I've looked at led power supplies but mostly they run to 30w until you go up to 12v.
I've looked at 1000/1200 PC psus, but I can't find one that supplies more than 30w on the 5v rail.
So, the need is to find, a 5v psu that can provide 1000w on a single rail. I'm not sure this exists.
All ideas and suggestions are welcome, but please bear in mind I've been searching for this solution for quite a few months now....
Many thanks.
Many thanks.
