100KW Install FIT rate | on ElectriciansForums
Discuss 100KW Install FIT rate in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
G
Greenday
We are looking at a 100kW field mount system for an individual and have a query regarding the FIT.
The FIT rate is 6.85 but as this installation will have to have an export meter will he get paid the additional 4.64p for everything he exports as well making the actual rate 11.49p/kWh?
The array will be grid connected but will not supply a building (autonomous)
correct I think, though does that factor in the reduction in FIT from 1st Jan for above 50kWp systems?
If he's got 100kW and is exporting it all he'll probably get more on the open market than the FiT rates, certainly he'd be naive not to investigate it.
If he goes down the Fit route, also who he sells his export to doesn't have to be the same provider that pays his generation tariff, and no the rate isn't, 11.49p as generation and export are two separate payments.
Reply to 100KW Install FIT rate in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
A picture paints a thousand words so here's an SLD showing my installation and some annotations to show the proposed relocation of the DC...
It sounds like the original meter was reading incorrectly and octopus aren't keen to admit this as they would probably have to refund you. I...
davesparks
