J
Jamie3032
Hi, does anybody on here have any recommendations for a relay that will switch (energise) @ 100mA 24 Volts, only need 1 x N/O contact for this
Discuss 100mAmp Switching Relay in the UK Electrical Forum area at ElectriciansForums.net
Maybe you posted in the wrong thread or misunderstood the OP, he was looking for a 24VDC relay that can be operated directly by a PNP signal.We like to use these, Wago 859-304. Good make and reliable.
859-304 - WAGO - RELAY, DIN, TERMINAL BLOCK | Farnell United Kingdom
You will also need an End Plate, Wago 859-525
Reply to 100mAmp Switching Relay in the UK Electrical Forum area at ElectriciansForums.net
