10mm cable crimps or screw connectors | on ElectriciansForums
Discuss 10mm cable crimps or screw connectors in the Electrical Tools and Products area at ElectriciansForums.net
Ta I use heat shrink at present, by screw connector I'm mean like strip but beefier, when I feel like it needs a bit more security ie on the vertical I cut the brass inards from a henly and insulate
Pict
Pict
What are you mounting them in? Or are you just leaving it insulated floating?
I'm imagining just big chocblock with insulation tape wrapped round.
Correct me if i'm wrong, but there are better ways to joint a cable.
Pict
Surely you are restraining the cable suitably where it is joined anyway? Whether it's crimps, a butchered henly block or anything else you should not place the joint under stress.
Crimps I do not trust on the vertical, and what half witted looney would not support 10mm or any other cable vertical or not,
personal preference, supported top and bottom of the joint, slack between on the vertical , either side and on the joint if horizontal, and I am not talking grey cable clips,
Reply to 10mm cable crimps or screw connectors in the Electrical Tools and Products area at ElectriciansForums.net
They are excellent, I have used them a few times for consumer unit relocations! They can get a bit tight with cables if you're using all the...
Thanks for that information I'll have a look at.
