10mm Sub main to garage Cu | on ElectriciansForums
Discuss 10mm Sub main to garage Cu in the Australia area at ElectriciansForums.net
geordie
Teesside
Is it ok to run a 10mm t+e in distribution trunking from a double pole henley block to a new cu unit in a garage. cable will have to go though a brick wall very short run.
Reply to 10mm Sub main to garage Cu in the Australia area at ElectriciansForums.net
Many thanks all. Very helpful to be able to bounce these things around. Was fairly happy with it all initially, but once the seed of doubt is...
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
