C
calv68
Hi everyone ive been to look at a board change in a two bedroom flat the db is supplied from a meter room with 10mm twin & earth via a 63 amp switch its a tncs system. The earth from the met in the meter room to the 63a isolator is 16mm but from there to the db is only 4mm coming from the 10mm twin & earth, its clipped direct so can draw 64 amps is this within the regs
