10w Cree XML DRIVER? | on ElectriciansForums
Discuss 10w Cree XML DRIVER? in the DIY Electrical Advice area at ElectriciansForums.net
R
rustypleco
hello i have a pack of 20x cree leds, however i also have a led driver at the moment
i was planning on using the driver to power 3x leds.
driver spec:
12v
2.5A
30W
Cree XML T6 spec
Model Type: Cree XML-T6
Emitted Color : White
Color Temperature: 6000-6500K
DC Forward Voltage (VF): 3.1 Vdc
DC Forward Current (IF): 3.0A
MAX Power: 10W
Intensity Luminous (Iv): 280-1000LM
Low thermal resistance: 2.5°C/W
Maximum junction temperature: 150°C
Viewing angle: 125°
Diameter :20mm
ANSI-compatible chromaticity bins
Unlimited floor life at ≤ 30oC/85% RH
Reflow solderable - JEDEC J-STD-020C
Electrically neutral thermal path
would it be ok/safe to run 3 of these from the driver? i have a decent heatsink
Reply to 10w Cree XML DRIVER? in the DIY Electrical Advice area at ElectriciansForums.net
