10W Xenon lamps in pendant fitting | on ElectriciansForums
Discuss 10W Xenon lamps in pendant fitting in the UK Electrical Forum area at ElectriciansForums.net
West Yorkshire
Could anyone advise me what kind of lamp a xenon lamp is as I need to get either a driver or transformer for 2 x pendants, each with 3 x 10w lamps in them, I didn't know if the xenon thing is just a colour, or if it's a concept of the lamp itself.
Cheers
Simple really, do you want an expensive lamp or a cheap lamp.
Nitrogen is dead cheap and works OK in lamps.
Argon is OK in price and lamps last longer and are more efficient than nitrogen filled.
Krypton is better than Argon but is expensive the tungsten filament will last longer and can run hotter and more effectively.
Xenon is very expensive and is better than krypton at allowing higher temperatures and better filament life.
All the same idea, maintaining the tungsten filament, just more costly as you go up the periodic table.
Anyway they will all be banned on energy efficiency grounds shortly so get them while you can!
Reply to 10W Xenon lamps in pendant fitting in the UK Electrical Forum area at ElectriciansForums.net
Hi Mike, Floating Neutral. I'm really over simplifying below, but using generators as an analogy is possibly easier to understand. In a large 3...
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
