11 235w Sanyo using 2500hf inverter | on ElectriciansForums
Discuss 11 235w Sanyo using 2500hf inverter in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Sykes
Hi all just like the thorts of the forum would you do one array of 11 or split in 2 arrays of 5 and 6.
My initial thort is that a 2500HF inverter has just one MPPT so installing on two strings of 5 and 6 panels sounds like a very bad idea. And that's before I get my calculator out.
Are these panels all going to be installed on the same orientation?
Reply to 11 235w Sanyo using 2500hf inverter in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
You can use timers to turn ON/OFF circuits during the day to maximize your self-use of solar power. Turn ON low draw circuits such as a 1Kw pool...
Hi all. OK... Let me just try and clear a 1" square space on the screen inbetween all the highly intrusive ads.... On a site (NHS in fact) and...
