110 volt | on ElectriciansForums
Discuss 110 volt in the UK Electrical Forum area at ElectriciansForums.net
M
mark not sparks
Chaps
I have just installed a 10 kva 110v site transformer on a job and put 3 double sockets in the garage for battery chargers etc
I have had a request from the builder and the client to put temporary 230v standard 13 amp double sockets on each floor (i assume the builder dont have any 110v tools)
Im not happy doing this but i am getting a bit of grief from the builder
I am trying to find out looking through the HSE website if this legal
can anyone help with the regs
thanks
Prob find its more likely from charging tools rather than using. There is nothing wrong in installing as long as its correct for enviroment. Problems with HSE is in its use which is not your problem as your not in charge.
Reply to 110 volt in the UK Electrical Forum area at ElectriciansForums.net
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
