110V air purifier with a 100-240V adapter | on ElectriciansForums
Discuss 110V air purifier with a 100-240V adapter in the UK Electrical Forum area at ElectriciansForums.net
Japan
I purchased an air purifier printed 110V. It has a power adapter of 100-240V. Can I use the air purifier with a power supply of 220-240V? Is the adapter also a converter or transformer? I’m really confused.
Thank you for your reply. It’s written as 100-240V. 50/60Hz. 0.8A
Output is 24V and 1A on the adapter.
Does that mean I can use the air purifier anywhere in the world since the power adapter is 100-240V?
You will find most power supplies these days accept a wide variety of input voltage and frequency (due to their type, ie. Switched mode). Yes, the adapter you have is suitable for most electrical supplies.
Reply to 110V air purifier with a 100-240V adapter in the UK Electrical Forum area at ElectriciansForums.net
I'm just trying to understand the current your suggested relay needs to handle. Surely the above is not the running current of the lamp? That...
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
