C
crabapple
was called out to look at a job - a pir floodlight was not working.
apparently the man just changed the lamp an now its tripping the cb. true it was.
there was jb with the feed off a local light, load (pir flood) and a switch.
i checked everything and could find nothing wrong.
the jb without the load worked , but as soon as i connected the load it tripped. i checked the continuity of the load cable and it was good.
i took the lamp out and connected the load and that seemed to work now!!
i did a continuity on the neutral holder to the neutral terminal and it was ok - no shorts
the line was also ok!
i did a continuity on the lamp and it was good, but it was then that i noticed the lamp was 500w @ 110v
now a 500w @230 = 2 odd amps
would i be correct in saying that 500w @ 110v = 4 odd amps and thus the overload????
