Hi all,
I have a charger that is fitted with a 240v rated 2p+E male inlet and a matching 240v rated female plug. However it is connected to a charger that is rated for 110V as it will be operated in the US. Is there an issue (if any) with supplying 110v Ac mains paired with the 240v rated plug and inlet?
is There any drawbacks to not using matching 110v rated inlets/plugs or even any benefits to using either option?
thanks
thanks
