12 or 24vdc to 240vac | on ElectriciansForums
Discuss 12 or 24vdc to 240vac in the DIY Electrical Advice area at ElectriciansForums.net
Bubba$
Alabama
My first post and please offer advice for a true novice. I’m trying to convert 12 or 24vdc to 240vac with a minimum of 5 amps. This will be of 1-5 sec duration and no more than 5 min of use per day.
Thanks, Bubba$
Reply to 12 or 24vdc to 240vac in the DIY Electrical Advice area at ElectriciansForums.net
Echo above, as someone who's probably similarly inexperienced I have set myself up a per point spreadsheet and whack it all in there. This has...
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
