HI All - need to run supply cables from the drivers to the ribbons in a new build. Its an ICF so will have min 10mm of plaster plus finish applied to what are effectively block walls. - Do i need to chase in the 12v DC supplies? and do i need to put these in conduit? - or is there a cement-proof cable/wire i can use? What do the regs say?
