12 Volt fan nightmare!!! | on ElectriciansForums
Discuss 12 Volt fan nightmare!!! in the Australia area at ElectriciansForums.net
H
hamlettphil
hi every one. ive recently replaced a 12volt extractor fan, it is a johnson & starley C25HPTLV model. it has an over run timer on, aswell as a humidistat built in. Problem is it never shuts off, ive fitted a lot of timed fans before, so i know the wiring is right. checked it several times. can anyone suggest anything apart from removing the humidistat from the fan?? Problems you may have come across before.
Reply to 12 Volt fan nightmare!!! in the Australia area at ElectriciansForums.net
