M
mustard
Hi,
hope someone will be able to help,
i have added downlighters to an existing lighting circuit taking a switch live, neutral and cpc from the j.b, i have only added four downlighters and when the first three are connected everything is fine and i have 240v, however when i connect the last downlighter lamp into to the circuit the voltage drops to 120v and the lights become dim!
Any ideas what may be causing this?
