Hi there all, I have a question.
I've just purchased this repeater:
Technique Specifications:
Item Specification
Up Link Donw Link
Frequency Range 890MHz ~ 915MHz
1710MHz ~ 1785MHz
935MHz ~ 960MHz
1805MHz ~ 1880MHz
Power -70 ~ -40dBm/FA (1.23MHz)
Gain 60±3 Db 65±3 Db
Max Output Power +23dBm / ±3dBmTotal Power +23dBm / ±3dBmTotal Power
Impedance 50Ω
Power Supply AC 110/240V (used AC/DC Adapter 12V dc)
Seclusion >70dB
Compact Design Indoor Use
Item Diemension 240 x 180 x 20mm
Connect Mode N connector
Ambient temperature -10°C~60°C
LCD display function
can display signal strongness which it receives from outdoor antenna ,
the signal bar will be full black if the signal is received very good.
The unit itself says 12v DC, but the actual power supply looks like it inverts AC>DC. I was trying to work out if there was a way I could hard wire this straight to my 12v battery bank in my motorhome?
The idea I had was to go straight from the battery terminals with an inline fuse, snip the end of the supplied adapter and rewire this to connected battery line.
Am I on the right track here? I am a complete electrical novice so please excuse my ignorance.
Much appreciated!
Item Specification
Up Link Donw Link
1710MHz ~ 1785MHz
935MHz ~ 960MHz
1805MHz ~ 1880MHz
Impedance 50Ω
Seclusion >70dB
Much appreciated!
