A 24Vdc door bell supply, provided by a transformer and relay near the main DB. Various bell-pushes and 24V bells around the site. All in mains-rated cable and often run together with mains looms.
The original bell in my workshop was not audible when machinery is running.
Single bell replaced this evening with a 24Vdc n/o relay, with mains supplied from a dedicated 2A MCB on a local Hager sub-main. No RCBO on this circuit. All cables clipped direct (and visible) in loft space.
The single-pole relay output powers a mains bell, and a 500W mains halogen light to give visible confirmation of the door bell. (I’m not sure how long the lamp will last with all that flashing from cold though.)
All the gubbins (note technical term) is in a Wiska IP66 box. Please ignore the untidy placement of the accessories: this is due to obstructions and cables behind the panel. The bell above the light is a telephone ringer, not related to the other electrical items.
A major re-wire at my house is nearly finished, and due for inspection and certification soon. This is the sort of ‘interesting’ detail which might be scrutinized. Not sure about the separation of LV and ELV in the same enclosure. Does it comply?
Thanks, Mark.
Thanks, Mark.
