12v blue led strip | on ElectriciansForums
Discuss 12v blue led strip in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
De Icea
hi thier i want to make my own blue 12v led strip like this
[ElectriciansForums.net] 12v blue led strip
i want to be able to use it in my car and on the strip i would like about 36 led's i had a look on ebay for the leds and i have come across these PACK OF 50 ULTRA-BRIGHT 3mm BLUE LEDs 5000 MCD on eBay, also LEDs, Components Supplies, Electrical Test Equipment, Business, Office Industrial (end time 12-Jan-09 23:17:22 GMT) i was woundering if i will be able to connect 36 of these up with the right resister in the right places which i would also need help finding out the right resisters and where to put them.
could anyone help me with this.
Evening,
Maplin sell these strips in lengths of 5CM for about 1.30 per 5CM length. Each length has 3 LEDs on it and you can buy whatever length you need in one piece. The good thing with these is that they work straight off 12V, no working out resistor values or anything and no soldering or makin lengths of strip up. Worth looking at. And they do different colours.
Hope this helps.
Reply to 12v blue led strip in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, I have a couple of questions I'm hoping you can help with. I have put a solar panel on my kids play house which charges a 12v battery. I...
Thank you for your reply. I manage to find the issue I think, the natural and live wasn't inserted properly in one the wago Further down causing...
