12V d/light & their transformers | on ElectriciansForums
Discuss 12V d/light & their transformers in the UK Electrical Forum area at ElectriciansForums.net
O
One_of_them
today had a fault on some d/l's. Kept tripping checked LN-E @250V and all clear. Dropped a couple of fittings and thankfully on 2nd found the cable after the tranny had been resting on fitting and disintegrated.
As said, found this on 2nd light so was happy but what if I had 20+ etc....is there a better way to check for faults after the tranny? Am i missing a trick?
thanks
if the installation is done correctly this heat/burning fault wont ocurr
the transformers and bits need to be fixed down -not just poked up thro the hole willy nilly
again couldn't agree more that installations need to be done correctly,
however fixing down the transformers???? how do you manage that in a ceiling? and then replacing it? OK in a loft but i wouldn't like to start pulling up half of upstairs to replace a tranny
Until some wally comes in and gets the whole loft insulated, over everything, downlights & trannys n all!
i'd never fix the transformers down unless there was open access from above. as sparky FM said, they need to be accessible for replacement.
Reply to 12V d/light & their transformers in the UK Electrical Forum area at ElectriciansForums.net
When you did the further testing and got the 0.06 reading were the CPC's back in the consumer unit? Really when testing you should leave the...
Hello Ric2013, MJPD29 and westward 10. I have a multimeter that I tested the voltage with and before I open the socket up I use a plug in tester...
