12v downlights | on ElectriciansForums
Discuss 12v downlights in the Australia area at ElectriciansForums.net
i=p/u
Northern Ireland
can you see any thing wrong with this telectrix, theres 33 downlights which will be switched from 4 switches and run off 2x 10A mcbs
20W / 12v = 1.6A x 33 = 55A am i lost here???
if they are 20watt downlights, the total power is 33 x 20 =660 watts. at 230v that's 2.87A. ( you've worked out the total current at 12v)
it does if you want to know the current at 12v. each lamp is 20/12 = 1.667A at 12v. total current for 33 lamps is 1.667 x 33 = 55A, but thats at 12v. to convert this to current at 230 you get 55 x 12/230 = 2.87A
Reply to 12v downlights in the Australia area at ElectriciansForums.net
