J
jvenning
Hi all, first of all sincere apologies for the lack of experience and inappropriate use of symbols! I'm putting together a remote mobile broadband station for use at events that can take a mains supply (transformed to 12v DC) or leisure battery.
I've obtained a 12V switching relay which works, if I supply the relay with two power sources it automatically switches to the strongest and should one be disconnected then it falls to the other. The issue that I'm having is that I have switched the supplies on entry to the box, if either of the switches is opened it doesn't take a supply from the other source but instead cuts the supply completely and in turn the 240AC - 12V DC transformer starts to buzz slightly - I'm guessing this is a bad sign! I would be most appreciative if someone could advise me what I'm doing wrong... I'm expecting it to be rather obvious but I can't seem to get my head around it. I've attached a diagram of my circuitry below.
Many thanks
James
Many thanks
James
