Dm7192
Carried out a job recently where i was installing a bathroom 12v manrose extractor fan how ever when the power was reinstated it failed to funtion i then replaced the transformer after relising there was no output voltage however even afterwards there was still no function. I may have made an error when trying to rush and only stepped down the switch wire & neutral from 230v to 12v without steppingdown the permanent feed for the fan timer, is it possible that the electronic PCB in the fan its self has been damaged by the 230v supply? Any help on the matter would be appreciated
