12v plinth lights plug top | on ElectriciansForums
Discuss 12v plinth lights plug top in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
C
Chrishands
Hi I need to install some plinth lights and have an old fcu socket that used to power an under cupboard fridge. However the cupboard units are not clumped together but are in 3 different sections. Can you buy plinth light kits where you can run a 12v extension feed off the module box to power anothe 2 module boxes. All interlinked? Or do I need to put 3 socket oitlets in each section of the room off the fcu and have 3 individual module boxes?
Any advice would be great. Thanks
Hum. How does the customer want them to be switched? All together or seperately?
Hi! This one will be for my own kitchen. I want them all to come on from the one fcu. I dont really want to start installing socket outlets everywhere if a 12v bolt on system exists.
Reply to 12v plinth lights plug top in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
It's a room where someone sleeps, so it's a bedroom. Minimum standards were set in the Parker Morris report in around 1963. Anything built after...
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
