12v rgb strip light power? | on ElectriciansForums
Discuss 12v rgb strip light power? in the DIY Electrical Advice area at ElectriciansForums.net
J
Joey Figo
Hi
Built a sliding door wardrobe and want to finish it off by having a 3 metre strip of RGB leds along the top edge of track to shine down on the glass doors. Is it safe / ok to NOT use the power adapter the light came with (laptop type supply) and instead have them powered from a 12v LED driver that is hard wired into the main bedroom lighting circuit ? Or is it just safer to stick with the supplied adapter? I only ask cos i wanted to free up the wall plug socket if possible. Many thanks.
You can connect a driver to the lighting circuit, but would suggest getting a local spark in, can`t see this being an expensive job
Reply to 12v rgb strip light power? in the DIY Electrical Advice area at ElectriciansForums.net
Hi all, I have a couple of questions I'm hoping you can help with. I have put a solar panel on my kids play house which charges a 12v battery. I...
Thank you for your reply. I manage to find the issue I think, the natural and live wasn't inserted properly in one the wago Further down causing...
