H
hdpete
Hi,
I have a small electrical device which draws 12 watts at 12vdc and needs to be powered from a 12v battery. Currently, it has a mains inverter from the battery to provide a stable 230vac which is then dropped using the device's power supply back to 12vdc. The device is a portable scanner and so will be very specific as to the input voltage.
There must be a more efficient way of powering this device direct from the battery, but when the battery voltage is dropping (to a minimum of 10.5v), the device still retains as close to 12v as is possible.
Can anyone point me in the right direction of some kind of 12v to 12v DC convertor which can provide a regulated supply on a falling input?
Many thanks for any advice
Regards
Pete
Regards
Pete
