13A BS1363 socket-outlets on a 40A MCB | on ElectriciansForums
Discuss 13A BS1363 socket-outlets on a 40A MCB in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
uk
Hi. I found a radial power circuit on an EICR yesterday wired in 6mm2 flat twin PVC cable and have some concerns. I know that the MCB is designed to protect the cable but what about the terminals of the sockets? 13A socket-outlets are rated to 20A max and I am not sure they are designed to have 2 x 6mm2 conductors in the terminals? I thought they were designed for 3 x 2.5mm2?
Someone could plug lots of appliances into the last socket on the circuit and overload the terminals, but the MCB would not disconnect. Should I code this?
The 20A limit (I think) you mention is for the load on a double socket, not the through-current on the terminals.
The basic principle behind 13A plugs and sockets is they have the protective fuse, so it does not matter (within reason) what the supply is, so long as the supply cable is protected. After all cooker switch/outlets often have up to 45A MCB feeds.
Would be limited by 13A fuse in plug, or 26 between two, as any other wiring method.
Not worth a code, but maybe a note.
Reply to 13A BS1363 socket-outlets on a 40A MCB in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
My wife’s Evoque gets about 32 miles on a full charge and I get about 28 miles on my F-Pace. I don’t know how long a full charge takes but I...
