13A Oven Install Query | on ElectriciansForums
Discuss 13A Oven Install Query in the The Welcome Forum area at ElectriciansForums.net
A
AnonzI
Hi,
I have just purchased a new oven which is 13A. The old oven was connected to a MK 45A DP Cooker Control Unit with Neon. Can I just connect the 13A to teh same socket? The previous oven was a Bosch which was rated at 16A.
Thank you.
Reply to 13A Oven Install Query in the The Welcome Forum area at ElectriciansForums.net
I've put a 2 way unit inside kitchen cupboards before now if we were re-using the original cooker supply but the customer wanted 2 x 16A ovens. I...
allowing for diversity a 32 amp supply will be fine for them both, but remember, the cable needs to be adequate to cope with a load on up to that...
