P
powervan
Hi in the kitchen there is a 10mm t/e existing and at mo its on old switchfuse next to a wylex board (rcd type) am going to pull it out of switchfuse (rewirable fuse) and fit into splitload wylex but wylex don't do 45amp breaker which I would be happy with do I put on a 40amp and hope at xmas the turkey isn't to big or just go for a 50amp and be done with it? I no 10mm can take over 60amps but range comes with a 6mm flex on the back so would be happier at 45amps!
