M
markharris
Hello guys,
A customer is purchasing a range style cooker, all electric, and looking at the specs it is listed as drawing a maximum of 15.9 kw which equates to 69A. I am wondering if any of you have installed a cable for this large an appliance. I am guessing that I would have to use a 16mm cable from CU to back of oven, and would probably have to split the tails and put the oven on a seperate one way CU containing a 63a RCD 30a incomer, and class this as the isolator, as it is just around the corner in a utility room adjacent to the kitchen, and will be about 2 metres from the oven. I am also guessing that there will be no Cooker Connection Unit, and the cable will go straight from CU to oven. Like I said it is only a short 2-3 metre run from CU to back of oven. Any ideas??
Many Thanks
Many Thanks
