15 degree felt roof | on ElectriciansForums
Discuss 15 degree felt roof in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Ric
Kent
Morning all,
i hope you can help, I'm looking for a non penetrative mounting system for a 15 degree roof. Covering is made up of either felt or a rubberised roof.
Has anybody ever installed anything like this?
Rich
We have done it 2 ways:
1) Used K2 slate hooks screwed directly (S/S Spax) to the rafters, with an edpm seal underneath and used a specialist felt roofer to seal it all, - end result was better than the original :)
Just as well MCS 012 hasn't come (and it looks as though it isn't likely to..) into effect. :)
2) a really nice unistrut fabrication tied into the building to avoid sliding, and large spreaders and ballast to cope with wind load, also placing a specialist material between the spreaders and roof to negate the effect of any possible movement (scuffing).
Calculations were interesting, there again we have qualified structural engineers working for us :)
BayWa.re do a specialised mounting for this type of installation.
Have a look at mounting feet from Danish company Jual. Specifically designed for felt, both cold and warm roof.
Can be specified with different types of felt system to match and maintain warranty of covering. Not cheap but very effective.
Thanks guys, customer doesn't really want us to penetrate through the roof fabric, but this has given some different options.
thanks again,
rich
Reply to 15 degree felt roof in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I would expect it to be virtually impossible to complete the project safely. how would you fix the panels to a roof that you can’t disturb? when...
Need to crack on to get most from this year :cool: BTW if you are thinking about adding to the strings later, i.e. add more panels to existing...
