15 downlights and 10 wall lights help | on ElectriciansForums
Discuss 15 downlights and 10 wall lights help in the Australia area at ElectriciansForums.net
P
paul kilbey
hi I got my c&g 2330 level 2 and 2392 and just started my c&g level 3 and ive just been ask to do a small job in a converted garage which is 33 ft x 10 ft and has a flat roof any trips
ive got to run the wires for the following
15 down lights on 3 dimmers
10 wall lights on 2 dimmers
2 spot lights on 1 switch
2 outside lights on pir and switch
1 light with switch for store cupboard
thanks paul
I work on 100w per bulb so 30x100=3000w P=VI so current draw is 3000/230=13A split over 2 circuits means 13/2=6.5A per circuit if equally split so no 2 x 6A mcb's will not be fine in theory (in practice they will probably not trip due to diversity and the bulbs not being 100W but then there are startup peaks etc (which may be overcome by using a type c breaker).
Use the P=VI formulae and the number of lights per circuit and you can work out the mcb size.
Once you know the mcb you will use then select the cable size to make sure it is ok and take note of the derating due to your installation method.
cheers
thanks paul
Some dimmers only work with a max of 200W - if the lamps are 50W x 5 for each dimmer then watch that - if they are 35W then you are fine.
(Sorry if I´m teaching you to suck eggs here).
Reply to 15 downlights and 10 wall lights help in the Australia area at ElectriciansForums.net
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
Thanks little spark. Good point but the drivers I'm considering have a sync and communication between driver function. So (as long as it works)...
