15 Sanyo HIT 240W .Which inverter? | on ElectriciansForums
Discuss 15 Sanyo HIT 240W .Which inverter? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
B
BillyH
As above.Got an odd number of panels so can't split up into strings so which inverter would be most suitable?
One with two mpp trackers, we're installting 15 sanyo HIt 250's on a SW facing roof with a Power-One PVI3,6 OUTD tommorrow.
Or SMA (There's probably more, those are the top two)
I like the communications from the SMA. - Still looking for a simple solution for the Power-One
Reply to 15 Sanyo HIT 240W .Which inverter? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
We had a similar call out and the issue was with the grid (which they admitted). Voltage was too high.
Hi all, This may is a little odd and may take some getting your head around but here goes... I measured around half the load current on two DC...
