1500 watt dimmer | on ElectriciansForums
Discuss 1500 watt dimmer in the Australia area at ElectriciansForums.net
T
Tapouchoke
Hi guys
I have a public house with a bank of switches x3 on each switch is 1100 watts of gu10 lights
the client has asked me to dim them I will be doing it adjacent to the board where the light switches are so space is not a problem any of you guys know where I can get three from as my wholesalers let me down
thanks for reading :cool:
another option might be to install a lutron system.... ive heard you can dim larger loads with there systems....ive never seen a 1500w dimmer think you might need a 47mm back box for it if you find one that will kick out some real heat.
Hi guys
I have used 1500 watt dimmers before but sorry I can't remember the make.They didn't fit a standard box,were only about 2 inches wide,about 8 inches high and about 6inches into wall.I'm pretty sure they were over a hundred quid. I once saw a variable speed drive used as a dimmer and I believe this costs a lot less.
I have a min of 9 GU10's to fit in a kitchen, the customer wants them all switched on together and dimmed.
Do i have to double the Wattage of each (50%) giving 900w total load, meaning I should buy the 1000w dimmer linked above ?? is this my only option? apart from splitting the lights in 2.. and is the buzzing from these dimmers when turned down anoyingly loud?
Do i have to double the Wattage of each (50%) giving 900w total load, meaning I should buy the 1000w dimmer linked above ?? is this my only option? apart from splitting the lights in 2.. and is the buzzing from these dimmers when on full load anoyingly loud?
Hi,I can't think why you would have to "double the wattage" but I recon I'd go for a standard 600watt
dimmer switch....and by the way the buzzing tends to occur when they are turned down to the minimum,this can vary with make you choose.
With halogen lamps, you have to derate the dimmer by at least 25%, this is for the 'arcing' that occurs within the lamp toward the end of the lamps life.
Reply to 1500 watt dimmer in the Australia area at ElectriciansForums.net
