Went to swap over an old fuse board yesterday, whilst I was removing it there seemed to be 3 ring circuits each protected by a 15A fuse. There was two live ends coming from each fuse. Tested each of the live, neutral & earth end to see if there was continuity & there was. Now, there aren't a lot of sockets on each circuit, the first one has 8 sockets including the kitchen sockets, but the only appliances that are in the kitchen & that would draw a large load is really the fridge. The other "ring" is for the ground floor which only has 7 sockets. There is a tumble dryer & washing machine run on this circuit, plus TV, Sky etc, again not too much load. The final circuit which is the 1st floor & 2nd floor has 7 sockets on it again no big loads at all, just two TV's. The thing I can't understand is why someone would have a 15A ring?! The installation is fairly old & I'm sure by looking at bits that there's been a fair bit of DIY done. You would think with the washing machine etc being on at same time it would blow the fuse? It wasn't until I had went back today & thought that maybe the fuse-wire had just been changed to 30A fuse wire, sadly when I went to check all the old gear has been dumped! I thought about tracing each cable but when I went to take the sockets off the lengths on each wire are so short I really think I'd struggle to get them back in! My obvious worry is that if I fit a 30A & it's not a ring the cable could overload. I crossed over my L & E at the board & went round each socket to see what sort of readings I was getting but to be honest it was up & down readings. Slightly puzzled to say the least. anybody came across anything similar?
