I have seen that with the old Wylex boards, but I have a feeling there is some regulation/guidance note stating the main isolation switch has to operate in an up/down direction (mentioned a couple of weeks ago on these forums).
[automerge]1587996574[/automerge]
Here was the post:
Find Consumer unit installed on it's side. Advice and Help. How-to Consumer unit installed on it's side. in the UK Electrical Forum advice boards on ElectriciansForums.net | Free Electrical Advice - Electricians Forums: Electricians' Talk Forums. Consumer unit installed on...
www.electriciansforums.net
[automerge]1587996696[/automerge]
@Julie. Also points out about the fire containment issue, as many covers are designed to close under gravity (which probably won't work sideways).
