15kva Transformer | on ElectriciansForums
Discuss 15kva Transformer in the Electrician Talk | All Countries area at ElectriciansForums.net
E
eddybs23
Been asked to run a feed for a 15kva transformer over about 40 meters for a site transformer. SWA Cable will be underground any suggestions on sizes and protection? Also would it be best to drop the transformer out and put a board in instead (as I have a spare three phase board hanging around my yard somwhere?
ive just done some v basic calcs. im guessing at a PF of 0.8, and arrive at at a figure of 45A from your tranny. I would install a 16mm SWA, and run it in ducting, to facilitate replacement, and to provide a new cable route. I would use a bs88 fuse, as it will comply with Zs, where if you use a MCB D type to 40A, it will not, and you will have to up your cable size to 25mm2
THE ABOVE IS WRONG, I messed up the calcs!
Bear in mind that the above was based on a TNC-S system , with a Ze of 0.35. in reality, your Ze will probably be lower, and you may get away with a D type MCB,. but please check first.
... it's a TNCS system Ze = 0.11 ohms - 40 meter run - it's on a bulding site and will be used to power 110v accsessories until the build is finished. I was wondering if i can take it straight out of the head into a rotary isolator with outlet to the transformer? If so what protection and where? Would 10mm be okay?
On 10KVA 3 phase transformers I use 4mm 4Core SWA on a 32A type D.
The fourth core is soley for added earthing security as more often than not transformers take a bit of punishment on site and glands are regularly pulled out.
Bear in mind this must also have RCD protection.
Hope this helps
As you say the cable is to feed the transformer the FLC will be 20.8A @ 415V so work from there. As has been pointed out expect damage to occur so protect accordingly.
I installed a temporary transformer in a steel stock ground a while back it was reduced to scrap within two days despite having a girder frame around it
I would also be mindful that you can allow a fair amount of diversity even though it is a single point circuit. I have carried out regular load testing on a variety of 10Kva transformer circuits ( up to 3 on radial ) and the highest loading i have seen is around the 10-12A per phase mark.
As I said before, this MUST have rcd protection if on a building site.
Reply to 15kva Transformer in the Electrician Talk | All Countries area at ElectriciansForums.net
I can't help wondering about earthing arrangements and how important aesthetics really are when attempting to make the best of a less than ideal...
nicebutdim
N
Thanks for the input guys. Lighting track is out of the question. The routing (h section guirders and angle iron) means that swa cable clipped...
