16 mm t+e feeding submain | on ElectriciansForums
Discuss 16 mm t+e feeding submain in the Australia area at ElectriciansForums.net
Hi all. been to look at a job where power is required for a garage. need to go back and take a second look. but on first visit i noticed a fully loaded second consumer unit in the kitchen feeding a number of circuits,from a main consumer unit next to the dno cutout feed with 16 mm t+e. i'm assuming its just using the earth in the t+e as the main earth. is that acceptable or should there be a seperate earth say at 10mm. seen this in a number of flats so assumed to be ok but not comfortable with it. just looking for your views on this? Its a t-n-s set up by the way.
many thanks in advance Daz...
Reply to 16 mm t+e feeding submain in the Australia area at ElectriciansForums.net
Does it really actually need earth sleeving inside the tube? I know it feels a bit bodgy but what's going to happen and isn't an unbroken...
BS3871 type 3's have a similar shaped operating curve to BS60898 type C's. Any fault that will meet the disconnection time of 5s (for 63A...
