C
craigsuds
A friend is installing a new cooker which has a rating of 16a. The old one was off a 13a fused switch wired on the kitchen ring as it was only rated at 10a. Can a 20a double pole switch be fitted in its place?
Discuss 16a cooker switch in the UK Electrical Forum area at ElectriciansForums.net
new one's 16amps then the question is no ,any circuit above 3kw should be on its own circuit so do the calcs 16amps x 230volt = 3.7Kw
What does the manufacturers manual say about it??A friend is installing a new cooker which has a rating of 16a. The old one was off a 13a fused switch wired on the kitchen ring as it was only rated at 10a. Can a 20a double pole switch be fitted in its place?
and???????????????????????I have run a supply for an oven and the firm said 16 amp supply
I may be wrong nick but isn't the limit 2KW,as I said I may be wrong, can you let me know which reg you are referring to please mine's at work and I'm on the sick with a bad back, old age again.
Reply to 16a cooker switch in the UK Electrical Forum area at ElectriciansForums.net
