R
Roxstedii
Hi there,
I am new to forum and looking for some advice on a hot tub installation.
I am going to be having a 16A hot tub installed in the next 6 weeks and looking for the best and cheapest way of providing eletrical supply. The hot tub requires a 16A supply with a Type C breaker. The reason for the Type C is because is because type B is too sensitive and will trip when the hot tub first powers up.
The actual consumption of the hot tub when on is 11.8A according to manufacturer.
I am looking to install this through using an existing 32A supply on the consumer unit that supplys power to just the downstairs sockets. Currently there is a Type B circuit breaker installed.
My question is, If I were to install a weatherproof minuture consumer unit outside (branched off an existing spur that is outside ) and install Type C circuit breaker on the mini consumer unit, will this stop the Type B circuit breaker on the main consumer unit from tripping?
I will be using a fully certified electrician to do the work, I just want to be completely sure of my facts before I get the work done and avoid any uneccasary costs.
Any help with this will be greatly apprecaited.
