16A MCB for a Ring Main | on ElectriciansForums
Discuss 16A MCB for a Ring Main in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
M
MHK
Howdy
I've come accross a situation where 16A MCB have been specified for ring circuits. The rings serve socket outlets having looked through the regulations I have been unable to locate any specific requirement stating that they can not be used, however, I would be grateful for some alternative views!
Many thanks in advance :)
The query wasn't necessarily as to whether you can or can't use 16A rings. There are approximately 200 ring circuits specified on 4.0 XLPE/LSF singles protected by 16A MCB breakers. I could understand if the intention was to reduce cable sizes by reducing the breaking capacity, however, this is not the case. I can really understand the benefit of wiring in this way?
Nothing wrong with using 16A ocpd for a ring final & you'll not find anything in the regs that says otherwise.
How big/long are the rings & what is the customer use.
The most likely reasons for the specification of 4mm[SUP]2[/SUP] XLPE (90 degree C operating temperature) and 16A MCB is this cable and it's protective device has been downrated because the cable is run through significant amounts of thermal insulation and/or areas of high ambient temperature and/or large number of cables grouped together.
Reply to 16A MCB for a Ring Main in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
Thank you for the speedy response! Have seen them on top of plaster in steel conduit before but guess it's not a common desire to have wires...
