16amp radial | on ElectriciansForums
Discuss 16amp radial in the Australia area at ElectriciansForums.net
Doble89
I have installed two rcd sockets in a plant room where I work I done this using 2.5 swa cable on a 16amp rcbo as there sockets will rearly be used the length is 15 m long is this ok
I disagree,
if there is a neutral to earth fault which device would trip?
unless there is a time lagging device like you have in a site MDU,
either the RCD or RCBO could trip and could result in a headache later
I would suggest that you downgrade the RCBO to an MCB.
The SWA has earthed armouring so an RCBO is not require
Richard
I think the OP means the sockets are RCD protected by having used an RCBO. In which case all is well.
yes I understand that,
if there is a Neutral to Earth fault on the device that is plugged into the RCD socket then there are 2 Residual Current devices in series in the circuit.
As I stated before either of the RCD, or the RCBO could trip.
If my reading of the OP is correct then they aren't 'RCD sockets' - just normal sockets connected to an RCBO.
I have read it about four times,it says to me,t he has run one swa 2.5mm fed from 1No 16amp rcbo, terminated to feed 2 No rcd sockets
Its a good enough confusing statement to compare with a lot of the regs
[ElectriciansForums.net] 16amp radial
Doble - could you please enlighten us?!
Well Rockingit, at least we agree about somthing
I also don't disagree with you that if he HAS installed RCD sockets on an RCBO circuit then it's not a good solution!
I thought it was just me that had been on the pop.......
Must admit, it reads to me that the socket-outlets are RCD type, and they are also protected by an RCBO.
Don't see the need for any RCD protection, unless the socket-outlets are to be used for mobile equipment outdoors?
Reply to 16amp radial in the Australia area at ElectriciansForums.net
Do you know what percentage of scheme registered electricians are registered to sign off 3rd party work? Even better would be a poll of how many...
nicebutdim
N
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
