16mm SWA on 100amp 3036? | on ElectriciansForums
Discuss 16mm SWA on 100amp 3036? in the UK Electrical Forum area at ElectriciansForums.net
Dave 85
Hi lads
So....was working in a top floor flat the other day built in '98 and I noticed the incomer was a 16mm SWA. I went down to the meter cupboard on the groundfloor and found it protected by a 100 amp switchfuse.
Now in the book if I remember rightly for a 70 degree 16mm SWA ref meth C the max is around 87 whereas for a 90 degree cable its 101 or something.
Either way I thought they were cutting it a bit fine.
If it is an error..its a pretty F'ing major error for a company wiring new build blocks of flats.
My questions are
Have the current capacity of cables in BS7671 been modified since '98?
How am I supposed to know if its a 70 or a 90?
If it is inadequate...would you demand the fuse downrated/cable uprated before carrying out work?
Already done the job so just an afterthought really...just wondered what you guys thought
Hi lads
My questions are
Have the current capacity of cables in BS7671 been modified since '98? Yes
How am I supposed to know if its a 70 or a 90? only xlpe cable is rated for 90 deg , it will be stamped on the sheath.
If it is inadequate...would you demand the fuse downrated/cable uprated before carrying out work? It should all work fine on a 80amp fuse.
hi , long time no see pal :)
Reply to 16mm SWA on 100amp 3036? in the UK Electrical Forum area at ElectriciansForums.net
