16th edition consumer unit & lack of 30m RCD | on ElectriciansForums
Discuss 16th edition consumer unit & lack of 30m RCD in the UK Electrical Forum area at ElectriciansForums.net
Mike66
Southwest England
Hi Guys
After some opinions.
Looked at a consumer unit today installed cu in 2008 under the 16th edition ie split load CU usual configuration cooker, immersion & lights on non RCD & shower & sockets on 30mA RCD side. The reason for the replacement cu in 2008 was to update the existing system
The customer recently had an electrical test & inspection carried out by the firm who installed the cu in 2008.
This cu was replaced just prior to the dual RCD requirement.
On their test they picked up that some of the circuits have no 30mA RCD ie circuits 1-5 on the non RCD side & have coded this as a code 2.
As you can imagine the customer is spitting teeth that a CU fitted in 2008 is now deemed to be potentially dangerous
Any thoughts?
The customer told me the lad who tested it was only 17, not too sure about that though, it was an NICEIC approved company nothing wrong with that I am too, but surely no one would send out a 17 year old kid to carry out testing, unless he went on a 5week course LOL.
This company does a lot of social housing & I think they are making a living out of changing these CU's
Hi Guys
Any thoughts?
yet more chimpish behaviour from monkeys...
tell em to bog off....theres nowt wrong with it..
as has been said so many many times before in here..its a 3....
eh?...lolffs...lol...lol...
They changed the cu in 2008 so they should have checked & it should have complied at the time
If done properly the the EICR should state if the supp bonds done. If so then the bathroom circuits are only a C3.
if the supp bonds not done they havnet done the job correct in the first place and she should have some recall.
she should still have the original test cert for CU change.
Tell her to go back to them and put it right
Reply to 16th edition consumer unit & lack of 30m RCD in the UK Electrical Forum area at ElectriciansForums.net
He said something about a fused something as the lights hardly take anything .. I told him was mostly cordless tools so just chargers ..told him...
those old mk rcds are very fast the figure you have quoted is the maximum allowed not the typical times,I have seen mk ones trip at 9 ms , the...
