M
mark7600
hi when setting up a twin rcd board with three neutral bars, can you put rcbos in after the main switch? I understand you can get problems with the rcds tripping out if the neutrals are placed on the wrong bar.
Would i put the fly lead from the rcbo into the main neutral bar that is supplying the other two rcds, and is being fed from the bottom N of the main sw.
Cheers any help would be great.
17th edition board set up
Australia
mark7600,
Guest123,
