17th edition boards opening a can of worms | on ElectriciansForums
Discuss 17th edition boards opening a can of worms in the Australia area at ElectriciansForums.net
B
baldsparkies
Just thought I would start a thread on this one
Having spoken to many electricians out and about, I am finding more and more referances regarding customer call backs due to nuisance tripping of RCD's.
We all know that before installing a new duall rcd unit, one needs to verify the reason behind the decision, along with a pir to identify any possible defects prior to installing.
The problem seems to be approaching and educating the general public who have experianced no issues with there 15th edition install, untill say, we come along because that nice new kitchen and its related electrics have to comply with our new red book.
The problem of course is they expect a fixed price for the job and you have to explain the possible additional costs for such things as putting right low insulation faults borrowed neutrals, replacing that old mi cable feeding the garage not to mention appliance problems,:eek: Well you get the jist of what I mean.
Anyway any of you lads,lassies, have any comments on this one or experiances to share, I must say I have been reasonably lucky so far but you could easily find yourself out of pocket with a red faced customer if you get it wrong.
Have changed a few boards in the past to 17th edition boards and had nuisance tripping.Spent most of the day trying to find fault,only to find a pinched or crushed cable,usually caused by someone catching the cable to the back box with a screw.
Borrowed neutral on the lighting circuits has been my biggest problem. Explaining that to the customer is not easy, "Well it was alright before!" is the usual reply
Mark
I know what you mean.If you put a 17th edition split board in, then every circuit should be on its own rcd and you shouldn't have any problems with borrowed neutrals.Hopefully.Depends what is installed in the house,but a majority of circuits will have a designated circuit.
The thing is its not easy to get the general public to realise you are quite genuine about things like a pir before a board change. We have all been left with the 17th fine,but the public are often ill informed or competely unaware of what can or can't go wrong. Some would say thats our job to explain and to a point thats true, but I am still amazed by the kind of electrical goodies that can be bought by joe public in most leading diy stores even now.There are still a lot of people who have no idea about part P or the legal implications attached. :confused:
When I am surveying a board change I always take time to explain the potential problems. Everything from interconnected circuits to nuisance tripping caused by appliances.
I also mention that to be sure a new C.U will operate a PIR should be completed beforehand. At that point I will tell them if there are any problems and how much they will cost to rectify. If at that point they don’t want to go ahead with the C.U change they just pay for the PIR until they can afford to pay for the remedial works. I also make sure that its also mentioned in the estimate letter,
The biggest problem I have with board changes is telling people there bonding needs to the replaced or installed, Members of the public cant see tangible benefit for that. But that’s a problem I have all the time regardless of what’s being done.
Ian
Reply to 17th edition boards opening a can of worms in the Australia area at ElectriciansForums.net
Do some of the free online tests. Get used to using the book. After doing this I passed mine easy enough.
I'm assuming the cable will have to be cleated well to hold it in place anyway, as a stuffing gland ain't going to hold it tight like a SWA gland...
