17th edition past papers.. | on ElectriciansForums
Discuss 17th edition past papers.. in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
shakin2011
Hello new to this forum and just popped in to see if anyone knows off any past paper resources on the net? theres no way one can digest the BS7671 in a short space of time, my test is in a week and i reckon by doing a few past papers will be the ticket.
So if any of you kind gentlemen and woman please impart some of those sources that would be great thx xo
Yes you can do past papers, it helps a little bit but the 17th is an open book exam. Best tip I can give you is just get use to the book, get to know where sections are located. Eg, where can you find out about rcd's, bonding, flc of 10mm cable etc. Btw look at each question very carefully, be careful if the c&g language, you can always discount one of the options and give yourself a one in three chance. You'll be fine, think there are some past papers in here, someone will point them out I'm sure. Good luck and welcome.:)
Upvote 0
I have past papers of 17th Edition (4MB PDF file) and also a PDF of 2382-20 (5MB file) if you want a copy.
Upvote 0
Can't help with papers but I've used the forums questions as practice looking things up in the reg's, works a treat. You just don't know what's coming up, very unpredictable so really does get you moving around the reg's.
Upvote 0
Reply to 17th edition past papers.. in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Electrical Courses
