17th edition Question ????? | on ElectriciansForums
Discuss 17th edition Question ????? in the UK Electrical Forum area at ElectriciansForums.net
sparkydan86
Hi guys,
Been doing revision for my 17th edition amendment 1, come across this Q, but dont how to work it out....
Q. A fault current due to an earth fault of negligible impedance in a 400v, three phase four wire circuit having an earth loop impedance of 0.3 ohms is?
a. 1383 A
b. 767 A
c. 124.5 A
d. 72 A
just another case of the meddling, unelected bureau rats in brussels interfering in UK affairs. we beat napoleon and hitler. why do we bow down to these johnny foreigners now?
I understand that we sort of went from 240 to 230 with some magic dust but it makes a laugh of doing volt drop calcs and upsizing the cable when what you really need is a decent resistor to get the volts down. They are even selling products like "V-phase" i think that drop you down to 220 if you want it so your light bulbs last more than a week.....
I now admit to installing an undersized SWA cable to a summerhouse, well it did not meet the volt drop calcs but guess what i loaded the cable up with a couple of heaters and yes it still would not go below 230v and i was drawing 20amps on a 2.5sqmm cable, its all a load of **olocks - BTW, just had a quick look and the wine in front of me was made in Australia .. HA
Reply to 17th edition Question ????? in the UK Electrical Forum area at ElectriciansForums.net
He is after the four options for 1 and 2 of the multiple choice exam, probably optimistic someone will know this. Your question 3 in incomplete to...
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
